Tile question
oldblue | Posted in General Discussion on November 27, 2008 06:13am
Is it better to tile behind wall mount micro wave or to tile up to it once it is installed?
  1. calvin | Nov 27, 2008 06:31pm | #1
    I will usually put a couple tile cuts up behind where the metal mounts to fur it out.  Avoiding the toggle bolt and anchoring holes that's I've marked out.  I'll run the tile to just up behind the metal-again missing the mounting holes.  Save enough tile to patch in later if newer micro is smaller in profile.
    http://www.quittintime.com/
  2. Jed42 | Nov 27, 2008 08:29pm | #2
    Mount the bracket, then do the tile. Then install the microwave.  Save some tile and grout in case you ever want to change to a regular hood.
    No Coffee No Workee!
