I’ll be installing about 350sq.’ of Cultured Stone by on the first floor of my house and will be doing a lot of cuts around doors and windows . I don’t want to rent a saw because I’ll be spreading the job out for a while. Could anyone recommend an inexpensive tile saw that will cut the stone veneer (about 1 1/2″ thick). This will probably be my only stone job so I’ll just be selling the saw after I’m done. Thanks
I have a beater sidewinder saw with a diamond blade I use for cutting cultured stone, concrete block, etc. And a 4 1/2" grinder with a diamond blade to clean up corners and edges.
I often use a shingle layed over the stone to protect the saw base and avoid marring the stone surface.
If any of your cuts will be visible, liquid shoe polish in a variety of colors to match the stone works and is protected when you put the sealer on it.
thanks Notchman. I too have an old skill saw...I might try that and save some $.
I only use my angle grinder for a few cuts, but break out the wet saw for anything substantial. If you're going to resell it anyway, why not get yourself a used wet saw on ebay, then sell it for what you paid. That way it only costs you the shipping one way.
Cheap Tools at MyToolbox.net
See some of my work at TedsCarpentry.com
