I’ve always had a hard time cutting small screws (#6, 8, 10, etc.), or steel rod stock which I seem to frequently need to do. I have one of those strippers/crimpers with threaded holes for cutting screws, but it’s never worked well, and takes a lot of force; usually messes up the threads at the cut. The other day, I had a eureka moment, and simply chucked the screw in my cordless drill. I then just spun the drill while lightly holding a hacksaw blade at the desired point. Worked great. I realize that if you do this a lot the lateral loading may wear out your drill, but it’s been a lifesaver for me.
BIll
If the stripper/cutters aren't working then you're putting the screw in the wrong way. Put it in so you have to go through the threads first then the cutter. When you make the cut you have to back it out through the screws. That straightens them back up and they are as good as new. Much faster and easier then using a drill and a hacksaw.
Well, you can tell by the way I use my walk, I'm a woman's man, no time to talk. .
http://www.youtube.com/watch?v=Dy3LM5_-i1Q&feature=related
Try to cut a NAS603 screw with a chinese made tool like that <G>
So NAS stands for National Association of home Screws?
john7ghaving a large inventory of AC hardware as well
Doh! Why didn't you tell me that back in the 70's!!!!!?It seems so simple now.... Bob's next test date: 12/10/07
You'd be amazed at the people that can't figure it out.
After cutting it i like to screw it in a little more and hit the end of the screw with a pass or 2 with a file and then unscrew it..
Nails and screws I use the Klein high-leverage hardened offset cutters:http://www.kleinconnection.com/webapp/wcs/stores/servlet/Category4_10001_10001_-1_12833
I just use a wire drill one size smaller than the threads on a piece of hard maple ripped to the size of the screw I need. Thread it in and put it on the grinder and use a die to even the first thread out.
I hold em with vice grips and run em through the table saw.Spheramid Enterprises Architectural Woodworks
"Welcome to Poo-ville, can I have your socks?Seriously Folks, I need a home for 3 lovers of your life.
LOL!
Run through a lotta saw blades, do yuh?
Put on your nut first, cut your screw/rod, then back it off. The nut's threads will carve/shape the threads on its way out.
