I am planning to install LP Smartside lap siding on our house. I am also installing a rain screen. The instructions call for a 3/16″ gap between butt joints for caulk. I plan on back priming the siding, the butt joints and installing pan flashing. Is it “really” neccessary to leave the gap and caulk if I do that?
Yup. Helps limit butt-end damage from expansion.
A La Carte Government funding... the real democracy.
Then I'm caulking my wife RIGHT NOW!Spheramid Enterprises Architectural Woodworks
wow.
prizeworthy...where's Rez?
Better cut her off from the hot peppers, too.A La Carte Government funding... the real democracy.
Now that'll cause some butt damage!!
Don't let Gunner have any of them.
my, how you've opened my eyes to the possibilities this thread has! however could I have missed it?
How quickly things can run down hill........As long as GOD makes "bad builders" and rich people... I will have a job
Don't blame him - his son was a carpenter, and while the rich and "bad" religious leaders criticized almost everything he said or did, no one ever had to re-do his work!View Image bakersfieldremodel.com
If you want any kind of warrantee, it is ALWAYS necessary to recognize that the manufacturer knows more about their product than you do.
This will grow in length with moisture and temperature, which is why a caulk cushion is needed.
I spoke with someone from LP. He told me that if I use a prefinished product I can pan flash the butt joints and not caulk if I prime the cut ends. It just doesn't seem reasonable to be that I can do that with a prefinished product but can't do that if I get the preprimed product back prime and prime the cut ends myself. Same product, go figure. I just hapen to think that some people are trapped in their "box" and can't think outside of it about alternatives that may actually be better in the long run.
Get it in writing.
not everyone at LP tells the truth,
Methinks I detect the ghosts of Breaktimes past dancing in distant rooms...
