To create a patio on moving soil
Barnacle Bill | Posted in General Discussion on April 10, 2006 01:16am
I am planning to build a ground level dry-laid brick or concrete patio on soil that is subject to movement from freeze/thaw.  If I use concrete, a reinforced slab on concrete piles will likely remain still while the soil moves away.  I prefer to use brick which will move with the soil but I want to minimize patio movement and weed growth in the seams.  I am in central Alberta where the soil is black gumbo clay, difficult to dig, very heavy, like concrete when dry, and sticky/slippery when wet.   How does one work with soil that moves to create a durable foot traffic surface?  I have lawn in the project area which is to be replaced with a hard surface patio.
  1. sungod | Apr 11, 2006 11:56pm | #1
    I would pour a floating slab. There would be no rebar because the slab would be divided into <5' squares. It would be formed up with Trex or some other synthetic wood. The forms would be grooved / keyed to keep the slabs alined with each other.
  2. kate | Apr 12, 2006 12:48am | #2
    What about using a geotextile under your pavers?
    1. FastEddie | Apr 12, 2006 01:54am | #3
      The geotextile will keep the sand from migrating into the soil, but it won't do anything for stopping the expansion/contraction of the soil.
    SamT | Apr 12, 2006 02:19am | #4
    2" subsurface insulating foam extending 1 1/2 times the frost depth past the edges of the slab. Example: if your frost depth is 4' and your patio is 10x20, with the 20' against the house, excavate a 16' x 32' area at least 8" deep. You will later cover the exposed foam with 6" topsoil around the slab. You can put 2" sand, or more insulation, under the slab so you don't have to pour a 6" slab. Use borate treated foam.
    No more freeze.
    SamT
    Edited 4/11/2006 7:20 pm by SamT
    1. Barnacle Bill | Apr 12, 2006 12:47pm | #5
      Thanks, Sam.  As I understand it your strategy is to prevent the ground under the patio from freezing.  And the blending of frozen-to-protected ground is gradual enough that the patio area should not move.....or if there is movement it is reduced enough that the pavers or slab is not affected.
        SamT | Apr 12, 2006 05:34pm | #6
        frost protected shallow foundationSamT
        1. Barnacle Bill | Apr 18, 2006 03:32pm | #7
          I checked the website you put me onto and got a better idea of what I need to do.  Our temperature drop here is to -40 deg Celsius which is -40 deg F.  The info on FPSF covers areas in Alaska and cold European countries also.  THe recommendation is to keep the soil beneath, dry and to use insulation under the project.  I will post results as I proceed.  Thanks for the link!
          1. HandySteve | Apr 18, 2006 06:26pm | #8
            Seen a sidewalk and patio poured over cardboard boxes.   Crush boxes I believe they called them.
            Just something I saw.  Dont know anything about it.
            when they put the boxes together, they were about 4 inches high or so.
            Anyone else seen this.. or do it?
Mortar for Old Masonry
