have a toe kick heater that is going into the heating system and have heard two differing opinions as to using the tee system or just running the heat pipe directly in/out of it .The toe kick heater appears to have a bleeder valve.
one says using the tees often create bleeding problems
the other says that you lose heat in the rest of the system .
opinions greatly appreciated
Really hard to answer without knowing more about your heating system design. How is the rest of the house heated? What is the piping layout?
Probably better off posting this at Heating Help's The Wall anyway.
If you already have a tee system, you will probably have to use tees.
Other ways of doing it but hard to say without putting eyes on it.
Both don't really know what they are talking about.
