Many opinons out there about how a toilet flange should be installed. Should the flange be level with finished floor ; or shouldit sit on the finnished floor (tile in this case)
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
I'd say the maximum height is with the flange sitting on top of the finished floor. Above that and the gasket gets squished too thin and you risk having the bowl actually ride on the flange. The minimum height is flush with the finished floor -- below that and you at least need an extra-thick gasket.
Mobdro is a free spilling android application, which is allowing us to watch two or three serious TV shows up, TV News and making us to watch general NEWS in this single application so download mobdro app from https://mobdroapk.org/
Have the flange sit on top of the finish flooring.
When you install the tile, make sure you leave cutouts in the tile so the flange bolt heads can be inserted where needed.
