Toilet Flange Connection??
cisco | Posted in General Discussion on March 12, 2008 08:57am
I am building a new house and had the “rough-in” plumbing completed by a licensed plumber with the plan to complete most of the “top-out” work myself. The toilet drain lines, which extend about 8″ above the concrete floor, appear to be four inch thin-walled lead pipe?. What type of flange do I need to make the connection to this type of material? I can do everything else without any difficulty and hate to call the plumber to drive a long way for just this task.
Thanks for any help or recommendations as to where to find some written instructions.
Cisco
  1. JulianTracy | Mar 12, 2008 11:22pm | #1
    I'm no plumber, but usually thin walled pipe is not used for toilet drains.
    Either way, you can cut it flush with the floor and use an internal cemented fitting or an internal ribbed rubber oring fitting - or - chip out the cement around the drain pipe and use an external cemented fitting.
    JT
  2. jayzog | Mar 13, 2008 01:21am | #2
    He probably used cast iron under the slab and you have a lead bend coming out of the slab. A brass flange is made that fits around the lead pipe which is screwed to the finished floor. The lead is then cut about ¾" above the flange and carefully flanaired out over the brass flange with a hammer- done.
    You can also just forget about the flange completly, just cut the lead about an 1½" higher than the finished floor , flair it over , and set the johnie bolts  into the floor with lead anchors.
    1. cisco | Mar 14, 2008 08:04pm | #3
      Thanks for the help. The drain line in the slab was PVC, so I am not sure why or how we got to a lead pipe. Anyway, I will look for the brass flange and see if I can finish it as you described.
Achieve a Flat Drywall Finish
These products and methods result in the clean lines essential to a midcentury-modern aesthetic.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
