Does travertine hold up well outdoors on a patio? I’ve heard its high maintenance.
I'd imagine it to be a nightmare outdoors, but have no first hand experience.
Consider this a bump.
J. D. Reynolds
Home Improvements
what is a bump. I've seen it before.
>> What is a bump?If nobody responds to your post, it soon sinks to the bottom of the list and then disappears from view. A bump is a non-responsive response, to keep the thread afloat in the hope that someone will come along with a real answer.
It's an upside-down dwnq.
I'm putting Travertine in a bathroom right now (floor and wall) and I wouldn't want to put it outside. At least not the stuff I'm working with. I would worry about it cracking and popping in freeze/thaw cycles as well as it scratching and wearing.
I'm sure someone else will be along with more and better advice.
No first hand experience. I'd imagine if you wanted to tile a patio with travertine tiles, the long term results might not be great. If you used pavers, should be fine, that's what they're made for.
http://www.builddirect.com/Pavers/marblepavers-Beige/ProductDisplay_9306_c2_10052526.aspx
I remembered these from a site i've ordered from. Look really nice.
Depends if it is filled & polished or unfilled. The unfilled will trap water in the crevaces and it could freeze and break the tiles. Filled & polished with a good sealer could work.
