Digging a post hole in my front yard. Found the underground feed from the transformer to my house. Nicked the insulation on one of the lines.
Would like to repair this with something better than electrical tape–some kind of clamp-on connector like those made for plumbing lines? I am handy, I have wired our house from the breaker box on out, but this is a new problem for me.
Call the power Co. They will fix it and not charge you....they will just be happy to see you alive.
>>>They will fix it and not charge youI'm not so sure. Around here they only accept responsibility for stuff before the transformer (the primary lines).I believe Burndy makes buriable repair kits. Pricey, but worth it. Ask at your local electrical supply shop.Scott.
tape and use the brushable coating ;
http://www.rudratechnocrats.com/products.htm
Near the bottom of the page. You shoud be able to find it at a local electrical supply house
How badly did you nick it? Can you see copper through the cut?
