Hi All, What is the best way to remove thick hard wood glue from a poorly repaired antique? Break is an end panel from cradle 3/8 x 22 ”
Listeners write in about sanding drywall, replacing a failed foundation, and making ground-contact PT posts last longer.
Depending on the type of glue, soaking it with warm/hot water should soften it enough to be able to remove it. Scrape off as much as possible before the water.Adding vinegar is supposed to help loosten the glue, but I haven't tryed that.
Be aware that any water might do some damage to the finish. If you are going to refinish the piece, no problem.
Try posting this over in Knots, too. They might come up with some other ideas.
