Using Dek Block Piers
| Posted in General Discussion on June 8, 2000 11:29am
I’m thinking of building a low deck in my yard using dek block piers.
According to ttheir site, I can place them right on level ground. I am
building in Connecticut, and I am concerned about frost heave and the
effects it may have on the dek blocks. Any suggestio
  1. Guest_ | Jun 08, 2000 03:01am | #1
    Hi Jim,
    Don't sweat it, they will never heave higher than the existing ground level.
    When you put them on top of the ground, they have no where to go,
    Gabe
    1. Guest_ | Jun 08, 2000 01:57pm | #2
      *Jim:Is this deck to be attached to the house, or is it free-standing? Are you planning on having it inspected by local building officials?
      1. Guest_ | Jun 08, 2000 07:28pm | #3
        *Free standing, and since it is not higher than 12" from grade, no inspection needed. It is treated as a patio
        1. Guest_ | Jun 08, 2000 11:29pm | #4
          *I think it will work out fine. I've used something similar to your dek-blocks, (maybe the same??) although not for an entire deck - just a few stair posts.If you go ahead with this, think about using .40 treated lumber - assuming you are using PT...
  • Townhouse Transformation
  • Mortar for Old Masonry
