I saw something today that I’ve not seen before. I was bidding a job for a local company, building some custom cabinets, when I noticed an electrician installing metal conduit along the walls where they meet the ceiling. He then was running a single red wire, looked like number 12 plastic coated, through the conduit and putting a loop at all the boxes. No nuetral, and he was running the wire as he assembled the conduit and boxes and attached them to the wall. After I finished making my measurements he was gone so I didn’t get an opportunity to ask what it was for. What could such a installation be? Is he going to return and put a neutral in later, it is for alarms, or something else??? Maybe if no one has any suggestions I will be able to go back and get his name so I can ask.
In issue #314, Fine Homebuilding published an article titled “The End of Deep Energy Retrofits” by Rachel White of Byggmeister. The premise was that deep energy retrofits are not as…
If this is power wiring the neutral has to be run iwth it and it has to be an insulated wire. The conduit is never to be used as a neutral.
Therorically a single wire could be run for an NC alarm system. But they would normally use a smaller size wire.
Without knowing anymore my guess was that it was not a wire, but rather a cable.
Could be phone, security, CAT 5, HVAC, etc.
It's probably for a fire system. They use red wire that looks about like a number 12.
I have no tagline.
http://www.hay98.com/
You are right, it is for the fire alarm system. I went back the am to turn in my bid and the electrician was there, so I asked. He showed me the wire, red and looks like number 12, but it has three wires in there, number 16. I'm sure glad I asked, I learned some things about clearances from the sensors he installed. In fact, he gave me a copy of revised code that hasn't been published in the book yet. Learn something every day.
Like they say. Questions don't cost a thing.
Pardon my fat fingers.
