It gets mightly cold here in Boston, so I’m looking to insulate my one-car attached garage, heat it, and use it as a woodshop.
I’m planning to insulate using fiberglass batts and wonder whether I need to bother with a poly vapor barrier. The garage will not be heated all the time, just occasionally. Also, the floor is concrete. Whad’ya think?
– Toolfreak
If your going to heat it, then treat it as any other heated room in the house .
Install a 6 mil poly Vapor barrier on heated side of studs/ trusses.
