venting a dryer
day off | Posted in General Discussion on October 8, 2009 06:29am
Any problems with venting a dryer through cement block wall? I have 1.5 foot of block above grade. Thanks.
    IMERC | Oct 08, 2009 06:39pm | #1
    will it get buried with snow???
    WOW!!! What a Ride!
    1. jimAKAblue | Oct 08, 2009 07:46pm | #3
      The heat melts a hole through the snow.
      1. DanH | Oct 08, 2009 07:49pm | #4
        If not buried too deeply.
        As I stood before the gates I realized that I never want to be as certain about anything as were the people who built this place. --Rabbi Sheila Peltz, on her visit to Auschwitz
        1. jimAKAblue | Oct 08, 2009 07:54pm | #5
          Imerc doesn't know what deep snow is.
          1. Scott | Oct 08, 2009 08:31pm | #6
            The dryer vent from our basement suite exits the wall about 16" above grade, and snow hasn't been an issue. Mind you, our house has 24" overhangs. YMMV.Scott.
            IMERC | Oct 08, 2009 08:43pm | #8
            yur right...
            no clue...
            WOW!!! What a Ride!
          3. Piffin | Oct 08, 2009 08:57pm | #9
            Nah - his drier vent is up ten feet in the gable end
            IMERC | Oct 09, 2009 12:04am | #11
            closer to 16 feet and that is exactly where it is...
            WOW!!! What a Ride!
        IMERC | Oct 08, 2009 08:43pm | #7
        and when it refreezes???
        WOW!!! What a Ride!
        1. Piffin | Oct 08, 2009 08:58pm | #10
          I read somewhere once that it should be 12" above the ground free and clear - no weeds growing up choking it of air flow
            IMERC | Oct 09, 2009 12:05am | #12
            think I read the same...
            WOW!!! What a Ride!
          2. day off | Oct 09, 2009 06:08am | #13
            Thanks all.
          3. junkhound | Oct 09, 2009 12:05pm | #14
            If you have a block wall basement, in MN where you need moisture in the winter, just build yourself a filter box and dump the dryer directly into the basement.
            Use a solar dryer in the summer.
          4. danski0224 | Oct 09, 2009 02:22pm | #15
            If it is a gas dryer, you are venting products of combustion, including carbon monoxide, indoors.
            UL listed CO detectors do not have to alarm until concentrations reach 200 ppm for over 2 hours. Concentrations at 15 ppm are damaging to the very young, and that damage is permanent.
            The detectors that plug into a wall are even more useless if the outlet is at the floor. CO is lighter than air, so CO won't even reach a floor level plug in detector until it is too late.
            Not a good idea.
            Edited 10/9/2009 7:27 am ET by danski0224
          5. DanH | Oct 09, 2009 03:20pm | #17
            CO is about the same density as air, not lighter or heavier. Otherwise, what you say is true.
          6. junkhound | Oct 09, 2009 04:54pm | #18
            good point, was just thinking electric dryer
        IMERC | Oct 09, 2009 05:07pm | #19
        forgot to mention no air flow and the clothes never dry...
        WOW!!! What a Ride!
        1. jimAKAblue | Oct 10, 2009 02:56am | #20
          The birds nest in our ducts and what should I do about that?
            IMERC | Oct 10, 2009 03:41am | #21
            eat it...
            and have the eggs for breakfast..
            WOW!!! What a Ride!
          2. DanH | Oct 10, 2009 05:44am | #22
            Get a vent like this:
          3. jimAKAblue | Oct 10, 2009 07:01am | #23
            No thanks...there's too much snow associated with that one. I dang near froze to death today...it got down into the 60's.
          4. DanH | Oct 10, 2009 07:04am | #24
            No kidding -- that style of vent (if you don't mind how ugly it is) is the best. Seals absolutely tight, yet allow free flow when open. No rattling in the wind.
            IMERC | Oct 10, 2009 07:20am | #25
            don't sweat the small stuff...
            we're hoarding it all up on the rim...
            scary quanities of it...
            WOW!!! What a Ride!
          6. Scott | Oct 11, 2009 06:18pm | #26
            >>>Get a vent like this:How's that thing work? Is there a backflow restrictor?Thanks,Scott.
          7. DanH | Oct 11, 2009 09:20pm | #27
            It consists of an elbow that diverts the flow upward. Inside the "can" is a floating cap that floats upward with airflow (resulting in very free airflow) and downward with gravity. The seal when down is nearly perfect, and wind won't "rattle" it.
  2. DanH | Oct 08, 2009 07:38pm | #2
    I think you need to make a hole in the wall first. Otherwise, a wall is a wall. Block is actually fairly good in that moisture from the vent is unlikely to damage it (though it'll collect lint a little worse than smooth wood/metal/plastic).
    The main reason you don't see it done more is probably that it's (a little) harder to cut a hole in the block than to go up a foot and cut one through the rim. That and the need to keep the vent above the snow line, high enough to prevent rodent entry, etc.
  3. danski0224 | Oct 09, 2009 02:33pm | #16
    No problem at all.
    Core a 4.5" hole in the block and put the vent in.
    Alternately, you could drill a 1/4" pilot hole through the block in the center of the desired opening, draw a 4.5" circle, score the outline with a chisel and then neatly chip out the block, working from both sides << edit. Very easy to do especially if you stay away from the middle and edges of the block where the reinforcement is.
    A plain old carbide tipped masonry drill bit made for plain old rotary drills will go right through cinder block. About $10 at the local hardware store.
    Edited 10/9/2009 8:25 am ET by danski0224
