venting a microwave oven
woodpeckers | Posted in General Discussion on September 11, 2012 04:35am
i am buying an over the range microwave oven. my stove is located on an interior wall and i want to vent the microwave to the exterior wall. total run of vent is 15 feet with one elbow.appr 4 feet to the ceiling and 11 feet across the kitchen ceiling. is that to long for the excaust to work? my only other option is to vent it back into the kitchen. i dont do any heavy cooking. thanks for any help.
  1. calvin | Sep 11, 2012 06:42am | #1
    wood
    Find the model you are interested in and look at the install pdf or booklet.
    They will give you adjustment numbers for transitions, elbows and vent ends.  Add 'em up and see if it exceeds the recommended length for your micro.
    Offhand, you should be ok.
    From Whirlpool:
    rect. to round transition-5ft
    90 deg elbow- 25ft
    wall vent end- 40ft.
    straight pipe-required footage.
    Their recommendation for one of their ovens-140ft total.
    so, you have 70ft in transition/elbow/vent end plus 15' or 85'.
  2. DanH | Sep 11, 2012 07:50am | #2
    I assume this vent is for the integrated range hood?  Microwave ovens don't generally require venting.
    Is there any range hood over the stove now?
      xxPaulCPxx | Sep 13, 2012 05:21pm | #3
      Over range microwaves have the range fan built into the bottom and a vent in the top rear to be piped out.
      1. DanH | Sep 13, 2012 07:52pm | #4
        That isn't what I asked.
