Venting Problems
ewing | Posted in Energy, Heating & Insulation on November 30, 2003 03:28am
Hello – this is my first time using this, so I hope I do everything correctly.  I need advise on the following.  We are have a new house built.  Under the overhang, the builder has been several vents for air to come in and vent thru the roof cans.  My question and concerns are the in vent is 8″x16″.  If I am lucky, the workers only cut in a 3″x6″ opening.  Will this not cause me venting problems especially in the hot, humid summer months.  Could this also cause mold problems due to not enough air input?  Any recommendations, suggestions would be greatly appreciated.  Thank you.
    rjw | Nov 30, 2003 05:40am | #1
    D:
    Where are you located? That is a key piece of information because different areas have different needs, and what works in one area doesn't work in another. Also, the size of the openings doesn't mean much without knowing how many there are.
    As a very general rule of thumb (and one that isn't very precise) you need 1 sq inch of free vent space in the attic for every 300 sq feet of attic space if there is a vapor barrier on the ceiling, or for every 150 sg ft if not.
    Divide this 50/50 between the soffit vents and the through roof vents.
    Note: Free vent space isn't the rough opening - another inaccurate rule of thumb - with the slotted cover on, figure 1/2 of the rough opening for the "free vent space."
    Note also, if you question the builder, you might well get "We always do it this way." Ask how often he returns to see if "this way" actually works. Some do, so do not.
    For an impartial view, try asking an experienced home inspector in the area (someone with over, say 1,000 inspections.) S/he'll have seen what works and what doesn't work and won't have an ax to grind or fundament to cover.
    _______________________
    Tool Donations Sought
    I'm matching tool donors to a church mission to Haiti - we're shipping a bus converted to a medical facility in January (we hope) and can fill it with clothes, tools and all sorts of stuff needed in that poorest of all countries. A few hand tools or power tools can provide a livelihood for an otherwise destitute family. Please email me if you have tools to donate.
