i’m planning to do my own foundation,a rectangle 28×32, with icf’s. any suggestions are welcome,but i’m really curious about the best way to vibrate the forms and concrete. thanks.
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
Here is a good report on the subject:
http://www.icfmag.com/documents/PCA_Consolidation_Report.pdf
Manufacturers recomendations would be a good place to start. Some can be vibrated with an electric vibrator, some don't recommend it. Alot depends on wall height, lift height, slump, bracing, etc.
Brudoggie
I use a 1" diameter "pencil" vibrator tip, somewhat sparingly, but vibration is really important in the high walls I've done to ensure consolidation around window bucks, rebar, corners, utility passages, etc.
I use AARX and this was their recommendation and it hasn't failed me yet after eleven foundations.
