first if i spelled it wrong oops! does anyone out there know where i can find a single 8″ exposure vynill siding in a different color than white? any help would be nice.
mastic does make a single 8″ exposure but only in white. the thickness on it is .048″ with a 3/4″ reveal.
Edited 5/11/2004 8:46 pm ET by unioncarpy
Have you checked mfgrs web sites to see if such an animal even exists? I would start there and do some detective work.
Whenever you are asked if you can do a job, tell'em "Certainly, I can!" Then get busy and find out how to do it. T. Roosevelt
Probably you can't. Anything over 5-6" doesn't have enough stiffness, so the wider vinyl planks are made with a double plank profile.
Of course, vinyl can always be painted, if you're able to find it in white, and don't gag when you see how that wide a plank looks.
Aluminum - with a bead.
Try http://www.certainteed.com
From my understanding they are associated with wolverine, ashland/davis and a few othewrs. You know, companies owning other companies, increases their share of the market
thanks for the info looked at the web site and they had something close to what i need.
