Found plenty of sources online for Voga (now apparently a part of Hafele) knobs/handles, but none for deadbolts. I need satin nickel spacer rings and two tailpieces. Does anyone know of a supplier for these parts?
Thanks!
Fine Homebuilding Recommended Products
Metabo HPT Impact Driver (WH18DBDL2)
This impact driver is a small, light, and powerful tool featuring three hammers and anvils instead of the usual two.
Loctite Foamboard Adhesive
When foam board installations require an adhesive, it’s important to use compatible products like this adhesive from Loctite.
Magoog Tall Stair Gauges
These are a must-have when laying out stairs with a framing square. They attach easily and save time, especially on long or multiple stringers.
Guardian Fall Protection Pee Vee
This tool is a gem! You can use it to align plates with your snapped lines, and it’s especially helpful when working alone.
Flashing Boot
Adequately seal vulnerable vent penetrations through the roof with this galvanized flashing and flexible rubber collar.
Been there, done that ... but then, where I live, I don't have access to a locksmith who has boxes and bins of old spare parts. But it definitely doesn't take the standard issue parts. Just started looking, not ready to give up.
