Does anyone have installation experience with the Jeld Wen Warmboard. It takes the place of the subfloor and has a 0.025 AL plate bonded to the 1″ Plywood. The plywood has 12″ on-center channels for running PEX.
I was traveling the path of a suspended slab (gypcrete) and all the gluelam beams are sized. However, it’s still on paper….
Does anyone have experience here?
Is thermal mass important?
Will the 12″ on-center layout be limiting?
Should I place hardwood directly on top?
What about others… Stadler & QuikTrak
Thanks in advance….
Does anyone have installation experience with the Jeld Wen Warmboard. It takes the place of the subfloor and has a 0.025 AL plate bonded to the 1" Plywood. The plywood has 12" on-center channels for running PEX.
I was traveling the path of a suspended slab (gypcrete) and all the gluelam beams are sized. However, it's still on paper....
Will the 12" on-center layout be limiting?
What about others... Stadler & QuikTrak
Thanks in advance....
