We were slow in getting a roof on our log home and we have some water stains. The DF logs were handcrafted so I don’t want to sand them. Any suggestions from the Pro’s out there. Thank you!!!
will you be treating or staining the logs???
the roof on now???
got a pic???
is it water stains or did the water draw out the tanin acid???
WOW!!! What a Ride!
will be treating the logs, tannin-Daaah, would send pic if I knew how. thanks alot
use the search function on how to
'post pictures' wealth of information... get infranview to help size the pics.. cake and pie...
gotta figure out wich prob ya have.. then we go foe removal, clean up or camoflauge...
more cake and pie...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Often, those stains can be sanded out. If not, use one of the Oxalic acid-based wood stain removers. Log home supply places will have them. Some of the better deck stain removers are oxalic acid based.
From the log home suppliers, it may come in crystal form to be mixed and diluted with water, or a liquid that can be cut with water. I usually mix it a little on the light side unless the stains are old and deep. You can apply it with a garden prayer or a brush.
After the solution has had the prescribed time to work, I usually scrub the stains out with a stiff bristled brush, like a masonry brush.
Don't use household bleach.
