I may have to leave 2700 sq ft exposed for up to 8 weeks, before the roof goes on.
What is a good strategy to prevent degrade of the OSB ?
Spring often times stays wet for some period of time, and OSB has a tendency to swell.
I’m thinking of spraying the decking with Thompson’s Water Seal.
Any comments welcome.
Build up a scaffold with a slight slope and then tarp it. Be sure to leave air vent space around the edges, and check frequently for leaks.
go to the big box stores nd buy up a bunch of off color paint.. exterior..
paint it.... several or even many coats...
WOW!!! What a Ride!
13146 WOW!
TRIGGER
huh?????Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
# of your posts!
TRIGGER
damn....Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
chech pif's #...
now that's gettin' up there....Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Way impressive IMERC!
TRIGGER
not bad fer my 1st rodeo... huh....Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Sh!t Howdy!
Sons o B!t( h!
TRIGGER
ya still gotta call up Piffin's profile...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
IMERC,
I've seen the one they call PIFFEN once.
National Geographic. May 1973.
Being 14 at the time, you can use your imagination.
I turn the page.
There it was.
The one they call PIFFEN.
SHOCKING!
Haven't been right since.
TRIGGER
that had to be a Puffin...
Pif wasn't a mere 14 then...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Dry It In!
Roll out the 30# felt paper starting from the bottom up.
Use 30# felt paper fasteners per directions in your area.
Cheap, effective, and lasts longer than visqueen.
TRIGGER
If you haven't put the OSB down yet, go with Advantech - mine was exposed for approximately 6 months w/ lots of rain & it's fine.
what soultrain said.
The 3/4 Advantech may cost a little more but you'll save more than that by NOT buying coverings and wasting your time prepping.
