I am replacing a set of exterior stairs on a rooming house. The area under the stairs needs to stay dry because the washer and dryer are located there. When I pull out the old rotted stairs I would like to put some sort of continuous waterproof material under the new risers and treads that would keep the water out. Thoughts?
Metal Roofing.
Unless you're the lead dog, the view just never changes.
thx for the idea, i'll use it
ditto on the corrugated sheet material,just be sure to allow for drainage @ bottom step.
