What and How to mount Hardiboard Trim?
BilljustBill | Posted in Construction Techniques on March 2, 2008 07:53am
  I’m about to start trim work on the corners, seams, and around the dormers of the shed that’s sided with Sierra Hardiboard vertical siding sheets.
   Is there anything else I can use other than the $10 1x4trim, or ripping the $15 1×5 Cement Hardiboard trim?
   Would you use 3″ galv/epoxy screws or 3″ ring-shank galv. nails for the trim?
  Thanks,
   Bill
    Sphere | Mar 02, 2008 03:43pm | #1
    I like the Azek. They also have pre made corners ( in 5/4 for sure, not sure about 3/4) and a 1x6x8' is about 26 bucks..but I'd rather cut that all day than Hardie trim.
    I use 2.5" SS trim screws and SS finish nails...that's all.
    Matt | Mar 04, 2008 02:57am | #2
    You don't want to rip a lot of hardi trim if you can avoid it.  Better to plan your job so the material can be used in the widths it comes in.  Actually I don't like the stuff anyway... too fragile and only comes in 10' lengths (I think) so more waste and more seams in the finished job.
  3. WINSTALL | Mar 04, 2008 04:58am | #3
    Go with the AZEK. It works just like wood and paints well. Better than HARDI...
  4. MSA1 | Mar 04, 2008 05:33am | #4
    I tried the hardi trim. Thought it was a good idea I had two windows (in two different bathrooms) in the tub enclousure. I cut my boards to fit and tried to assemble with my trim nailer.........not so much. The nail didnt even come close to working.
    Plan B: Get out the screws, oh wait you cant screw near the edge of hardi, it blows out.
    I ended up having to predrill and countersink every hole then very carefully install the screws.
    It wasnt too bad for my small project but I might think twice before tackling a big project with this stuff.
Versatile Vise
