what can i do with a big ol’ (24″x18″) metal return air register right in the middle of the floor in my 1940-ish house? its ugly and it hurts my bare feet! does it need to be this huge?
put it in the wall and duct it in....
what's hooked to??? basement or crawl space unit...
can you use a joist bay for the return duct to the perimeter of the room or wall???
wear shoes or slippers more often...
step over or around it...
WOW!!! What a Ride!
Is it still in use? Connected to the furnace return?
If so, you can't do much until you provide an alternative return, and that does NOT include just leaving/creating a big opening in the return near or at the furnace.
With my mouth I will give great thanks to the Lord; I will praise Him in the midst of the throng. For He stands at the right hand of the needy, to save them from those who would condemn them to death.
- Psalms 109:30-31
Bart,
Are you sure it is a return ? Most of the ones I have seen in the floor are actually the hot air "outlet" for the system.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Floor furnaces had a big heat vent.But the old gravity (octopus) furances had a bir floor return right over the furnace..
You need it because if you take it out you'll fall into the basement.
Throw a rug over it and it won't hurt your feet so much.
http://www.reggioregister.com/category/3
If it's really a return, you can replace it with individual returns in each room. Then floor that one over.
Lots of new ductwork, but the system will look and work better.
