Heres four pics.
If you’ve used this before, say so but don’t tell too quickly.
I’m just curious if many have seen this used or used it.
blue
Just because you can, doesn’t mean you should!
Warning! Be cautious when taking any framing advice from me. There are some in here who think I’m a hackmeister…they might be right! Of course, they might be wrong too!
speed square trueing tool.
Buck Construction
Artistry in Carpentry
Pgh, PA
Hehehehe.
Nope!
Just because you can, doesn't mean you should!
Warning! Be cautious when taking any framing advice from me. There are some in here who think I'm a hackmeister...they might be right! Of course, they might be wrong too!
I have never seen it or used it before so this is a guess.
When you have a joint of two pieces of cut drywall and need to make a smooth joint with mud, you wet the joint with water, then run this tool up and down to compress the joint. Let the joint dry, then mud and tape as usual.
DaneI will always be a beginner as I am always learning.
Dane, that is the closest guess, but it's not right.
blueJust because you can, doesn't mean you should!
That was my though, but it did not look right for that job with the "wings" on it and the long handle.
hair splitter
tile grout scaper
This tool is used to tuck the plumbers' T-shirt back in.
Heck If I know....
Edited 4/14/2005 9:19 pm ET by HECK
Looks like it's used to heat or melt together two pieces of vinyl cold joint seals. My brains stumoed for the right word. It's white is half way buried in a foundation pour like a keyway when you add on for length or turn a corner you have to heat the two and weild them togther.
If not what the hey.
flashing creaser
sobriety is the root cause of dementia.
We always called that stuff "water-stop." But it was an iron that we used to weld it together.I had fun putting in a decent amount of water stop in a water treatment plant UV radiation tank.
That's a rudder for a duck's a$$ with the optional landing gear.
drywall tape in corner smoother
I think BB got it right, Drywall corner roller?
TA DAAAAAAAAA!
Brown bagg, you get the milkbones!
This pic shows the tool in the corner. Obviously, the person that did that corner didn't use this tool. If they did use this tool, the mud would be scraped off perfectly clean even with the edge of the tool. The blades are stout and they leave a perfect amount of mud every time. It gathers extra mud while its dragging the corners clean.
It also pinches the tape into the corner perfectly.
This tool is very fast to use. You slop on the tape using a box or by hand, then run this thing over it.
The first time I saw a taper using one, he ran all the ceiling corner tape in three rooms and ran the tape down four feet at each corner. After slopping three rooms of tape in about five minutes, he picked this tool up and cleaned them up in half that time.
I bought one to do my last project and every corner that I used it on started out perfectly. I managed to mess them up on the cover coat!
If you drywall by hand, this is a money maker.
Blue, maybe you should mix some coffee into your second coat.......
Joe H
Well I guess I was in the right church just needed to move up a couple of pews.
Thanks for the brain teaser. Got any more?
That must be a decorative concrete tool you saw your new team using?!
Second guess is the plumber crack addresser.
Stu
Blue,
I'll go with BB's guess - suspicious unknown white substance on tool looks like the crust in the corners of my drywall tools. Sporty nylon roller!
Jim
Never underestimate the value of a sharp pencil and good light.
i dont know what that is.But mabye it's something that women in the previous discussion could use to get those rotten deck boards out.
