I will need to make a spline for use with 2 grooves in a hardwood floor install (engineered). what should I use? run down and grab some small stock of oak or something?
Trouble-free performance begins with properly installed line sets that pass rigorous testing for leaks.
SawStop's Portable Tablesaw is Bigger and Better Than BeforeRelated Stories
Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
Podcast 551: Members-only Aftershow—Badly-Built Homes
Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
that oughtta work...
WOW!!! What a Ride!
1/4" oak plywood, and cut with the face grain. That makes the spline floppy because the thicker core veneer is cut across the grain, but it provides more resistance to shearing when installed.
Some flooring stores have spline or slip tongue in stock, and will sell you a piece or two.
Thanks guys
