bump
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
I would think that you know the volume of solution that you need to release paper. And a new wainscot below should be protected from the drip.
If it was me, I would feel responsible.
Quittin' Time
Unfortunately I agree with Calvin. I think it's yours to fix. And i don't think the wood will lay flat again after it dries out.
I agree, you own some previously installed Wainscot.
Just tuition in the school of business.
"Enjoyning the finite of matter, in an infinite realm of possibilities...
Youre the expert. Thats what people pay you for.
You knew what had to be done.
you should have included what ever it was in your estimate.
Do the job right or leave it to a pro.
You spray chemical on walls? You better know what the consiquences of each chemical has in the areas you're working in. Even just water alone.
I don't get it...am I missing something here?
You just soaked the walls and didn't worry what would happen behind the wainscotting? Ohhhhhh boy.
Be well
a...
If Blodgett and Gunner say, Tipi tipi tipi it must be so!
TipiFest 06~~> Send me your email addy for a Paypal invoice to the greatest show on earth~~>[email protected]
Once you took the job and started you were responsible for the out come .
Tim
It's on you. I doubt the adhesive failed. More likely, the wainscot is a ply that wasn't ever designed to get wet. It did, and it started to delaminate.
"Sometimes when I consider what tremendous consequences come from little things, I am tempted to think -- there are no little things" - Bruce Barton
Guess this thread was about some kind of screw up?
Guessing paperhanger didn't get the answer he was looking for?
Joe H
You and I both missed the fun
Nowwwwwww do you remember what they used a steamer for?If Blodgett and Gunner say, Tipi tipi tipi it must be so!
Unfortunately, one of the assets of BT is that if you are, in fact, on crack, there's no shortage of people very willing and able to bring that to your attention.
