Ive been using EZlay around foundations for some time now and it seems to work well.Its easy to install and the popcorn foam w/ filter cloth keeps out dirt and such.
I have noticed some type of sheet that some builders have been nailing up around the foundation below grade that looks simple to apply, just dont know anything about it-if it works well, cost ?
Black with drain channels facing the block. Anyone, anyone.
The best tool for straight, splinter-free cuts is made even better without a cord.
Battledrain or similar propriertary systems. It is to provide a drainage plane for the path that water can follow to the actual perimeter drain. The fater water can drain down without resistance, the less likely huydrostatic pressure is to force it in through the foundation wall.
Without a foundation drain, it is worth little.
Think of it as a turbocharger on an automobile. It will help it function better, but the wheels and engine still need to be there and be functional before the turbo is any good for anything.
