I’m considering making a solar water heater for a small pool and thinking of using PVC for the piping. Should I be concerned about any chemicals from the PVC leaching out into the pool water? I have looked around on the internet and haven’t found any info saying one way or another.
Thanks in advance
let see they use pvc for drinking water and you are concerned about a pool with a filter
I guess my question is do I need to use CPVC or is the cheaper pressure PVC suitable?
yup...
WOW!!! What a Ride!
Not all PVC BB.But for an open pool I wouldn't worry on that score. He will get more pollution out of the sky than out of the lines. I'd select for ease of use and longevity.
http://www.buildiitsolar.com
Everything and more about solar pool heating.
Joe H
Swimming pool liners are made of PVC.
In a word: NO
Indeed, I'd use as little 'hard' pipe as possible. Where you must, use copper. I've had even CPVC pop apart on solar instals.
For heating a pool, the simplest way to make collectors is as follows:
Border 4'x4' pieces of plywood with 2x2's, and make a coil of black drip irrigation tubing. Cover with plexigless (NOT Lexan). Pump water through. Use a separate pump
If I could, I'd set the collectors to best catch the 7AM sun. I'd also make a point of covering the pool at night.
I understand about the hard pipe holding up, but would you be concerned about any chemical leeching?
There are a million solar pool heaters in Florida and every single one is plumbed with PVC. Don't worry about leeching.
I am not concerned in the least about anything that might leach from piping of any approved material.
Ummm...Your question is, should you be concerned about PVC pipe micro-leeching chemicals into a pool into which you're gonna deliberately dump shovel-loads of chlorine?
Dinosaur
foolish men call Justice....
