What’s the difference between halogene pot lights with the transformer attached (DC?) and the ones that run on straight AC?
I tried this question in the Energy Etc folder but no clear response yet. Thanks as always, Patrick.
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
Two differences are:
FWIW, I'm not a fan of the dc lights. I had dc puck lights under my kitchen cabinets for a few years and seemed to be replacing bulbs every few weeks. I replaced them with ac pucks a couple of years ago and have only replaced two bulbs since then.
The big difference is that you can treat the wiring to multiple bulbs as low voltage.
For the same wattage and bulb type (incandescent, halogen, etc.) the light output will be the same and the heat will be the same.
The transformer uses a little extra power (efficiency) but usually not enough to worry about.
"The big difference is that you can treat the wiring to multiple bulbs as low voltage."Because he said that he was looking at cans with built in transformers.
Oops. Didn't notice that one.
Thanks everyone, can"t say as to why I should spend 2 times more for the low voltage ones, still doesn't make sense to me why anyone would go that way, unless you were doing a huge # of lights and even then an extra line is usually way cheaper. hard to see how the low voltage would pay for itself. patrick.
Actually this is the 3rd time that you have asked the questions.
http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=81405.1
http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=81377.1
And you have gotten good answers.
First LV lights are not DC, they are AC.
It depends on the specific can and bulb.
