I saw someting that i`m unfamiliar with up in the ceiling benath a second floor addition, it was what looked like to be white insulation and it was unfaced.Can anyone give me the scoop on this stuff does it have fibers in it like regular insulationand should it have a vapor barrier installed over it before the blue board goes up.Any help would be appreciated.
you sure ya wasn't in the attic , playin in the stuff for christmas decorations?
I`m going out on a limb here sphere and guessing you`ve never seen it either.I was just wondering if it was bad to be in that space and breathing it inwithout protection of some sort if it was going to be like that for awhile, they are waiting on blueboarders to come and there is no vapor barrier on it.
nope, the only thing like that was called "angel hair" spun glass for xmas displays, I'll bet it is very much the same.
A white fibreglas insulation is sold around NW Ohio as unfaced sound and thermal insul. No or low formaldehyde content. Fibres don't fly around as much either.
Quittin' Time
I think Johns Manville makes white fiberglass insulation batts, and without the use of formaldehyde binders.
Pretty much same technical specs as Owens Corning pink fiberglass.
Regards,
Tim Ruttan
