why is this pex different on the end?
Just came across this pic and was wondering?
Learn about balloon-framing construction techniques, including stud patterns and efficient assembly methods with minimal manpower and scaffolding.
What do you mean by "different"?
That pic is of Uponor¯ FKA Wirsbo¯.
There is a ring that is placed on the end of the tubing that provides the strength of their joining system.
“The world is a dangerous place, not because of those who do evil, but because of those who look on and do nothing.” —Albert Einstein
I guess my question was about how the joint works. I can't see how it would work. All the pex I've seen is just tubing.
Edited 2/10/2008 7:12 pm ET by popawheelie
You expand the tubing and the insert a fitting and the tubing shrinks around it The band is to give it more "shrinking power".It is really part of the fitting and not the tubing. Kinda strange the way tht they show it..
Uponor pex has a 100% memory.
After you cut the tubing to length you slide on that ring, which is made of pex also.
You then insert the expansion TOOL after you expand the tube & ring, remove the tool & place barbed fitting into the tube.
Since the pex tube & ring have a 100% memory they contract back to their original size sealing itself to the barbed fitting.
Here I thought it just hadn't been circumscribed..(G)Spheramid Enterprises Architectural Woodworks
SNORK
