Window casing problem
Duey | Posted in Construction Techniques on July 22, 2004 05:53am
        I recently got a job finishing what another carpenter started. He was hired to bump out a dining room wall (exterior), about two feet with a sliding door and two windows in it. The windows are about 12″ wide and 40″ high. His crew just roughed it in and sealed it to be weatherproof. My job was to do all the finish work. Well, when they put the windows in, they installed the jamb extensions and nailed the windows in. The extensions were the kind that you drive into the window frame. They are all wood(the window frames.)When I came to install the drywall, I noticed that the extensions were 1/8 to1/4″ proud of the drywall surface. I should have used 5/8″ drywall as that would have helped.
         Now my question is how to install the casing. The walls are textured and painted. Do I try to plane or sand the jamb down flush with the wall surface or do I put a filler piece in behind the outside edge of the casing? I know this all could have been avoided if the extensions would have been ripped before installing, but what’s done is done. I’m afraid if I try to plane or sand the jamb, I will have a hard time keeping it straight. I would appreciate any advice anyone could give me. Thanks!
        Duey
  1. Davo304 | Jul 22, 2004 07:56am | #1
    Duey,
    You say you  can't plane off an 1/8th to a 1/4 inch with a block plane and you call yourself a finish carpenter?!!  C'mon now!
    Quit fooling around here. Even if you happen to ding the drywall, so what?...the new casing will hide it. get out the block plane and have at it!  You say you are afraid that you won't plane the edge evenly?....the jamb extensions are what...3/4 inch wide....one steady swipe across the edge with your plane and the board will be shaved evenly.
    If you are afraid to use a plane...don't hire out as a finish carpenter...block planes and finish carpentery go hand in hand...period. Just take very thin shavings with each stroke....less than 5 minutes of grunt work involved.
    Davo
    Ps...Now that I've vented on you, here are 2 other alternatives....chuck up a flush cutting bit equipped with a bottom bearing  into a small router and have at it. The bearing should be in contact with the drywall as you rout.
    Put a small rabbet on the front edge of your casing so as to slip over the protruding extension ( personally, I think this would look lousy, but experiment with a piece of scrap first and see.)
      Sphere | Jul 22, 2004 04:17pm | #2
      why do I envision that bearing bit idea makeing a HUGE problem?
        BillHartmann | Jul 22, 2004 05:41pm | #3
        Yes, the router is a good idea, but he trying to do it on the wrong axis, for several reasons.
        Use a bit that will cut to the bottom. Add a 1/4" spacer to bottom of the rounter faceplate so that is only covers about 1/2 of the faceplate.
        Set the bit so that it flush with the bottom of spacer. Slide the router with the spacer on the DW face and it will trim the extension down.
          Sphere | Jul 22, 2004 07:27pm | #5
          I agree, that bearing would sink into the SR too easy, and transfer all of the nail / screw dimples to the jamb..not a pretty sight.
          I always just block plane, old school ya know?
      2. maverick | Jul 22, 2004 07:20pm | #4
        They call that experience. One slip and yer replacing the jamb. Then you gotta plane the corners anyway.
        For me it would be easier to nail up the casing then float in the gap with durabond.
          Sphere | Jul 22, 2004 07:31pm | #6
          In 25+ yrs. of jambing, I have not encountered any jamb that needed more than a block plane, or worse case remove an ext. jamb and table saw to a scribe line, and touch up with a plane.
          Yeah, it's a freehand cut on the TS...but it works if yer careful.
          1. maverick | Jul 22, 2004 08:37pm | #7
            I cut scribes way too much on my table saws. I'm not a fraid to do it on the portable but I've had the unisaw kick back. That'll get yer hair standing up.
          2. Shep | Jul 23, 2004 01:52am | #12
              I thought I was the only one brave ( read: stupid ) enough to freehand thru a table saw. I don't do it with others watching, which isn't too hard 'cause I usually work alone. Basically I don't want others picking up my bad habits<G>
               Oh. and I have had kick-backs. No need for coffee after one of those.
          3. Summerwood | Jul 22, 2004 09:36pm | #9
            Similar problem recently.  I recently worked on an old multi-family that had a first floor fire.  Plaster and lath removed removed throughout, 1/2" rock put up.  The original window jambs stood 1/2" to 7/8" proud of new rock.  Too much material and too many old nails to use even my junk plane.  I went to Home Crappo and rented a Crain Jamb saw, did 29 large windows in couple of hours.  Only a few very minor paper tears in the rock to repair.  Few quick licks with plane to knock off blade marks, and cased the windows.
        IMERC | Jul 22, 2004 09:27pm | #8
        Because you can spell gouge (TTS) and know what tear out is...
        Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming....        WOW!!!   What a Ride!
          Sphere | Jul 22, 2004 10:05pm | #10
          a little hep here...was TTS?  am I asleep at the wheel or just frazzeled?
            IMERC | Jul 22, 2004 10:34pm | #11
            Turns To Shid....
  2. Piffin | Jul 23, 2004 02:00am | #13
    I don't know that I have everseen an extension jmab show up just right. Even the pones I make, I cut proud to start with and then plane down.
    You take you=r block plane and set it across the jamb edge at an angle so that the shoe rides the sheet rock finish and the blade is on the jamb. You end up done in no time at all.
    Dinosaur | Jul 23, 2004 02:34am | #14
    Block plane will give you the best job. Otherwise, cut filler pieces and slip 'em behind the casing before you nail the outside edge. The filler doesn't have to be the full width of the void; you can just take slices of the appropriate thickness off a piece of 1x pine.
    Dinosaur
    1. Piffin | Jul 23, 2004 02:36am | #15
      If it is only a little proud and is also uneven, I use the tip of a cedar shim right where I am nailing, and then cut it off and use caulk to fill the rest.
        Dinosaur | Jul 23, 2004 03:17am | #16
        I thought we were talking about interior casing. Caulk...?Dinosaur
        1. Piffin | Jul 23, 2004 05:08am | #18
          I did say that if it is only a little uneven...
            Dinosaur | Jul 23, 2004 05:59am | #19
            I think my problem is I'm imaging stained casing instead of painted. (Probably because today I just finished plugging about 2000 nail holes with Minwax Blend-Fil crayons and then hand-oiling all the moulding and woodwork for an entire basement I've been working on since October. Last item on the punch list!!)
            In a paint-grade job, your thin line of caulk would work fine and nobody'd ever know it was there.
            Dinosaur
            JeffBuck | Jul 23, 2004 08:51am | #20
            Cool .. I thot I was the only one stuck in a basement for the past year ....
            guess what's on the short list for tomorrow ...
            nail hole filling!
            JeffBuck Construction, llc   Pittsburgh,PA
                 Artistry in Carpentry
            Dinosaur | Jul 23, 2004 03:37pm | #21
            Next time I'm either gonna use Velcro to attach everything, or I'll colour-match the stain to my little guy's crayons and put him and his whole 1st grade class on the payroll for a day....
            Dinosaur
            jonblakemore | Jul 23, 2004 10:40pm | #22
            A whole year? Did you have to modify your estimating system to "that'll take about a month"?
            Jon Blakemore
            JeffBuck | Jul 24, 2004 05:22am | #23
            yeah ...
            "that'll take about a month ...."
            the 12 step program!
            honestly ... I'm trying my best to quit!!
          6. Duey | Jul 24, 2004 06:24am | #24
                   My thanks to all of you who responded! I have slowly been getting involved with more finish work and I found all of your advice to be helpful. I will be planing down the jamb. I don't know why I was so reluctant to try it. One more related question; are those power planers the way to go or is it just as good to use a block planer?? Thanks again!
        Duey
          7. PhillGiles | Jul 24, 2004 08:10am | #25
            One word: NAILS ! Hitting one with a low-angle block plane is one thing, hitting one with a spinnig blade is down-right excitement.
            Try to sink them with a drift-punch (aka: pin punch) if you can..
            Phill Giles
            The Unionville Woodwright
            Unionville, Ontario
  4. Sasquatch | Jul 23, 2004 03:18am | #17
    Not having seen the actual problem, I would, in a similar situation, go calmly to my toolbox on the back of my truck for my DeWalt Planer, which is easily adjustable to a highly accurate degree.
    Les Barrett Quality Construction
