I’m about to install new construction windows without a nailing flange in a brick veneer opening. The windows have jamb extensions are sized to be about an inch short of the exterior brick surface. Each window is custom sized to leave a 1/4″ gap around the opening that will be caulked. Do I need a window pan or water and ice to provide extra protection?
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
I'd say so. The window manufacturer should provide details.
Andy
"Never try to teach a pig to sing. It wastes your time and annoys the pig." Robert A. Heinlein
"Get off your dead #### and on your dying feet." Mom
I believe like andy that it would be the ticket to be able to include some sort of flashing but one that connects to the window frame won't be possible. You could wrap the inside of the opening with a sill pan, then bring either a metal or vycor wrap (from int. framing to brick) down to it. In reality slipping the window into the opening with that in the way will be nigh impossible, especially with the sizing you have. I have relied on Urethane caulk (first backer rod) sealing the opening. You'll see what I mean on the goofy opening you have left after you remove the old window. My experience is only with removing old metal frames which were sealed with caulk only. Best of luck.
Quittin' Time
He might figure out a way to cut a reglet into the edges of the brick as a way to attach a metal flashing.Andy
What's "reglet" ?
It's a fancy, archy word for slot. As in a slot where you might spring or caulk in a piece of flashing.Andy
Here is all the information & then some that you will need.......
http://fortifiber.com/
Also another good site....
http://www.TLSLabs.com
