I’ve run into a casement sash I need to replace due to a seal failure. The sash has no glazing beads, so replacing just the glass is not an option. There is an ID in the corner of the glass I’ve never seen before. Do any of you guys have any idea who the manufacturer is? Please see the attachment.
Thanx!
Edited 10/31/2005 7:48 pm ET by jocobe
try simonton windows. http://www.simonton.com/Default.asp?bhcp=1
Is there any writing on the division strip between the panes of Ins. Glass?
vintage 98 (in the code) glass in the window, does that line up with the age of the house or replacement?
Quittin' Time
Edited 10/31/2005 6:14 pm ET by calvin
There's nothing on the spacer bar (in between the glass). I forgot to mention it is a wood sash. Thanx!View Image
Wood sash with no glass bead?
If I wanted to know anything about glass.......I'd ask the couple of good old time glass shops in my area.A great place for Information, Comraderie, and a sucker punch.
Quittin' Time
The stiles and rails are finger-jointed in the corners.View Image
Well, don't that beat all. Make a sash and don't leave a way to replace the glass w/o dismantling. That company can't still be in bizness.A great place for Information, Comraderie, and a sucker punch.
Quittin' Time
I just got about 30 sash ( 24x30) exactly because of that. The HO wanted ( get this, single glaze) due to fogging..I explained I'd have to route CAREFULLY to remove the damn insul panel ..and make a glazed install or glass stop.
They decided to resash the jambs with TDL single pane sashs and liners...I got the old sash. Even reused some in my shack. Spheramid Enterprises Architectural Woodworks
"I don't think it's funny no more" Nick Lowe.
bumpView Image
Another option, if you can not find the manufacturer would be to have it custom milled.
We've done that twice in the past, local millwork shop comes out takes the measurements and 2 weeks later we can have a new one, certainly not cheap, but cheaper then a whole window
