Window tracks info needed
| Posted in General Discussion on June 5, 2000 07:02am
Hi!
Does anyone know where you can buy replacement window tracks?
My windows are double hung and run in aluminum tracks on each
side. I’d really just like to replace the tracks with non-heat conducting
vinyl ones and weather strip like mad. I seem to only find whole
window replacements. I’d rather not spend the bucks.
thanks
-Lisa
  1. Lisa_Wintler-Cox | Jun 05, 2000 07:02am | #1
    Hi!
    side. I'd really just like to replace the tracks with non-heat conducting
    window replacements. I'd rather not spend the bucks.
    thanks
    -Lisa
  2. Guest_ | Jun 05, 2000 07:02am | #2
    Check with a company called Blaine window or hardware. I think you can find them on the web. They carry every piece of window hardware ever made.
    If you cannot find them write back i have a catalog somewhere.
    You may be in for more work tthan you thing to change or retrofit your windows
    Good luck
    David
