Windows, Windows & Windows
jjp2222 | Posted in General Discussion on June 15, 2020 04:49pm
This project concerns two sets (4 windows to a set adjacent to each other) of ’70s Andersen wood casements.  The windows face West and recent tree removals at a neighboring property has resulted in  afternoon sun pouring in, causing temps to rise into the 80s and HVAC can’t keep pace.  The windows themselves are in very good shape, no rot and look okay for being close to 50 years old.
The simplest option would be to replace each bank with new windows.  The contractor I’ve been in discussion with claims I need to install new construction windows.  I’m loathe to go this route as we just had the house resided with Hardie Plank and Boral trim in 2018 – I’m not keen on the potential for them to damage the siding.  Also I’m at a loss for why they can’t just use replacement windows, any ideas?
Andersen still sells replacement sashes for these windows but they’re just standard double-pane glass, not low-E.  Is it possible to get custom sashes made with low-E glass or is it cost prohibitive?
The last alternative I could think of is having a professional install some sort of film to cut down on the heat gain or maybe even buying new sashes then having the film applied.
I’d love to hear ideas/thoughts?  Thanks
    sawdust_steve | Jun 16, 2020 09:02am | #1
    Speak to a glazing contractor or a glass shop. They should be able to swap out the panes for you with custom glass.
  2. richpark | Jun 19, 2020 10:19pm | #2
    You have nothing to loose. Why not try window film. I have had moderate success in both autos and homes here in Texas. Window films will void warranties but yours are old. It will certainly be more economical than re-glazing.
  3. Brody30 | Mar 16, 2022 12:35pm | #3
    Well richpark is right. You have nothing to lose, hence you can experiment. I would recommend to invest in Dako Windows USA.
Fast, Accurate Wall Framing
