I am looking for a wiring diagram for a breaker box, a web site or such. I”m wiring a new box for two 30amp RV receptacles. It will be hung on an outside pole. I already have everything I need,box with two 30amp breakers, wire service coming from a master box with a master switch, I have done this before but to feel safe I would like something I can look at to make sure everything is hooked up correctly.
Thanks, ZABO
If you need a wiring diagram on how to wire up a breaker box, maybe you should call in a professional?
zabo
if you're looking for a refresher check out this link.
or like natedaw said if you haven't been down this road a pro might be a better choice
http://www.hammerzone.com/archives/elect/panel/sub_panel/01/overview.html
ZEEYA
ps
do you know the words to the song "you light up my life"
if you're looking for a refresher check out this link.http://www.hammerzone.com/archives/elect/panel/sub_panel/01/overview.html
That link doesn't work. Try this, instead:
In other words, get the 'L' out...:)
Bob
Edited 3/27/2007 12:00 am ET by bobguindon
Thanks ZEEYA and Bob, that's exactly what I was looking for, very good article. I promise that I'll be very careful and have an electrician friend of mine check it out before I turn anything on.
ZABO
Edited 3/27/2007 4:20 pm ET by ZABO
just a word of caution,guy here got killed with his rv plugged into a improperly wired outlet. the outside metal skin instead of being grounded was hot. rainy day,he grab the door handle and that was it. don't guess. larry
