Wiring in-line attic vent fans
I’m convinced that I should install an in-line vent fan in my attic. How do I wire two baths to operate this one fan. If it were just a three way switch someone in one bath could turn it off while it was in operation in the other bath.
Thanks for you thoughts
A reporter once sent a telegram to Cary Grant asking “How old Cary Grant?” Grant responded “Old Cary Grant fine, how you?”
Do you already have the unit? It should come with wiring instructions. I have never wired one before, but I would imagine just catching the old bath fan switchleg would be all you need to do.
If you are using a switch separately from the light switch you just wire them in parallel.
It might be desirable to use a switch with indicator (pilot light) so show when it on. Note that this is different Lighted switch.
If you want to use a timer you can wire mechnnical timers in parallel.
If you want to use electronic timers then I think that they will work, but pick one and then check the instruction and/or the manufcature tech support.
If you want to have them on with the light(s) then use 2 pole switches. One pole is for the light. the 2nd is for the fan and again just paralleled.
What Bill said. I just did this ... in line fan ... serves three rooms ... utility, 1/2 bath and full bath. I LOVE it ... used a Panasonic 250 CFM Wisper fan ... so quiet I hardly know it's on. It is controlled by 3 single switches ... any one turns it on. My older haouse had a similar setup ... except they used crank timers ... that way it doesn't get left on ... it always turns itself off ... which I may switch to a later point in my new house.
I did exactly what bill described about 6 months ago for someone. The backlit switches work well for this situation. As if the fan is on the backlight is off on both switches.
you got a legend to go w/ that wiring diagram? :) Thought I was looking at a sea creature for a second, there!
