Wood Flooring patch-up questions
graffito | Posted in Construction Techniques on November 21, 2004 06:50am
What’s the right NAIL to use for hand nailing unfinished oak strip flooring?
Should I drill a pilot hole for each nail?
It’s a patch job in one corner of the room. The rest of the floor is finished (poly), so I’d appreciate any tips to make the patch look reasonably well-matched.
It doesn’t have to be absolutely perfect, as there will likely be a built-in of some kind covering a lot of it.
Thanks.
  1. Piffin | Nov 21, 2004 07:42pm | #1
    I normally use 8d galv finish nails.
    I cut the head off one and chuck it in a drill to initiate each hole. burns them in but makes a tight hole without splitting. Sometimes I use glue too depending on what that might do to movement in the rest of the room.
    Finish? The patch is going to look like a patch until it gets refinished over the whole room
    1. graffito | Nov 22, 2004 12:05am | #2
      THANKS!1. Do you use galvanized because of worries about staining, should the floor ever get wet?2. Would rib-shanked nails be too much? (I think these are usu. used in underlayment.) The subfloor is 2x4's.
      1. Piffin | Nov 23, 2004 01:20am | #3
        Ringers would be great if headless. Heads would prevent next course from seatiung tight with that head in the tongue edge.I guess I use galvies just because that is all I use for anything, except when I use stainless. Too near salt water here.
