working with Corian
Dave10990 | Posted in Construction Techniques on September 26, 2008 07:20am
I am making new counter tops for our boat. (With this economy, I might just move back aboard and sail to someplace warm, and work for nothing there).
I started rough cutting the Corian so I could route it with the templates I made.  The jig saw was very slow going, the table saw did ok, and the final routing was slow.  What is the best way to make the sink cut-outs.  I will be using drop ins, not undermount. so I don’t need a perfect cut.
  1. TomT226 | Sep 26, 2008 07:36pm | #1
    Use your template that comes with the sink, and mark it out in contrasting color marker or crayon.  Drill a 3/8" hole near a corner radius. Cut around the line with your jig saw LEAVING TWO SPOTS NOT CUT.  Flip piece over and use some ply or 1X and double-stick tape to support the cut-out on an already cut area.  Flip it back, and finish the cut.
    Put some cut-bait on the rod, and grab a beer. Yer done...
    1. Dave10990 | Sep 26, 2008 09:09pm | #2
      What blade in the jig saw?  It seems like very slow going to cutting with a jig saw.
      1. carlmccarty | Sep 27, 2008 01:27am | #3
        I just installed a solid surface shower requiring a cut out for a shampoo shelf. After going through a jig saw blade every 4", I got out my circular saw with a fine tooth carbide blade and made the cut quicker and smoother than the jig saw.
      2. TomT226 | Sep 27, 2008 01:03pm | #8
        Don't know the number right off hand, but it's a wood/metal blade, and I set my Bosch for a pretty agressive cut.  Should go through 1/2" Corian pretty quick.
        If you're like me, you got more time than money, so be patient.
  2. highfigh | Sep 27, 2008 02:23am | #4
    Get the right blades, for starters. Also, an orbital jigsaw, like a Bosch works a lot faster.
  3. Dave45 | Sep 27, 2008 02:24am | #5
    Corian can be worked pretty well with carbide saw blades and router bits, but it plays hell with steel.
  4. gfretwell | Sep 27, 2008 05:23am | #6
    A cutoff wheel in a table saw, skill saw or side grinder goes right through Corian.
  5. BUIC | Sep 27, 2008 08:05am | #7
    "so I don't need a perfect cut."
      Actually, you do, so to speak.
      After you make the cut out, you need to sand the edge smooth and break the corners.
      The saw marks are little starting points for possible fractures. DuPont says any cut needs to be sanded smooth, even if it'll never be seen... buic
  6. Frankie | Sep 27, 2008 08:02pm | #9
    When I took the Corian fabricator's course to get "certified" I was told jigsaws were not an approved tool for cutting. They leave tiny fractures which will grow over time.
    Routers or circular saws only. Make a template and do a two or three passes.
    Frankie
    Flay your Suffolk bought-this-morning sole with organic hand-cracked pepper and blasted salt.
    Thrill each side for four minutes at torchmark haut. Interrogate a lemon.
    Embarrass any tough roots from the samphire. Then bamboozle till it's al dente with that certain je ne sais quoi.
    Arabella Weir as Minty Marchmont - Posh Nosh
    1. AitchKay | Sep 30, 2008 03:59am | #10
      Frankie and BUIC got it right. You can rough it with a jigsaw, just make sure you leave enough material to smooth out with the router.
      Smooth cut, radiused corners= no stress points.AitchKay
      1. Adrian | Sep 30, 2008 05:44am | #11
        You can use a jigsaw, but yeah, all the saw marks have to be routed or sanded out to prevent stress risers.  Once the sawmarks are gone ( or any marks left by saws or drills), the source of problems are gone. Lots of radius work gets done with jigsaws. I don't understand the 4" comment.....I just did a job, cut about 40' of radiuses with a plexiglass blade in a jigsaw, and it seemed basically brand new at the end.
         Cabinetmaker/college woodworking instructor. Cape Breton, Nova Scotia.
