5′ variable speed pc random orbit s…
| Posted in General Discussion on April 19, 2001 02:02am
I bought one yesterday, it goes from 5000 to 12000 rpms, has a soft start and is doing a really nice job. The old 5″ pc is going to get a lot of rest.
  1. Wes_S. | Mar 23, 2001 05:54am | #1
    Was there anything in particular wrong w/the old one?
    How old?
    Mine's ten yr.s old.
    Wes
    1. brisketbean_ | Mar 23, 2001 02:37pm | #2
      *Wes; The old ones are working fine, but the variable speed feature is a very good upgrade, it is great for detail sanding into corners and such.
      1. Wes_S. | Mar 24, 2001 03:39am | #3
        *Thanks,BB- Merely gathering info when I can.Sincerely,Wes
        1. jim_"crazy_legs"_blodg | Mar 25, 2001 04:40am | #4
          *I've been using the Dewalt varriable speed 5" for a few years now Bean, and I agree, the ability to change speeds is great. I have to replace the variable speed dial about once a year though, they are real sensitive to dust and I guess the vibration. I'll be interested to hear how long your PC switch stands up. The Dewalt switches are about 30.00 each.
          1. brisketbean2 | Apr 18, 2001 03:40am | #5
            *I just finished a stain and laquer job where i utilized the sander with 220 grit paper and a vacume attachment in between coats at the slowest setting and it did great, the paper lasted an extrordinary amount of time. I love it.
          2. Mike_M. | Apr 18, 2001 05:08am | #6
            *Hmm. Interesting approach, Brisketbean. There could be some intriguing possibilities here. Do you think that using it with a scotchbrite 000 pad, 1000 grit wet/dry, or something along those lines would work for deglossing a surface, or as an intermediate step before rubbing out a finish? Mike
          3. jim_"crazy_legs"_blodg | Apr 18, 2001 05:42am | #7
            *Yeah, you can get up to 2000 grit at an auto body supply house, maybe finer.
          4. brisketbean_ | Apr 19, 2001 01:32am | #8
            *Mike; I used the scotch brite pads for deglossing on my high speed PC for deglossing enamel, but i was useing this variable speed for sand sealer and laquer, it is a labor saving device for sure, without sanding through on the edges, with a little care. I was sanding probably a 100 square foot of wood paneling with one 220 disc.
          5. Mike_M. | Apr 19, 2001 02:02am | #9
            *Brisketbean-Wow. I'll have to remember the scotchbrite trick for sure. Sounds like you're onto something here. I'll keep my eyes peeled for a good deal on a VS ROS. I like my 333, but if this is any indication, my 333 may be meeting an early retirement. How did the final finish turn out? Any discernable difference between it and a hand sanded finish?Mike
  2. brisketbean_ | Apr 19, 2001 02:02am | #10
    I bought one yesterday, it goes from 5000 to 12000 rpms, has a soft start and is doing a really nice job. The old 5" pc is going to get a lot of rest.
Shoulder Your Buckets
Add a strap for easy carrying and pouring when working with 5-gal. buckets.
  • Townhouse Transformation
