delta multivalve
Ejc | Posted in General Discussion on June 8, 2013 08:08am
Evening,  Hoping somemone can help me,
I tried to change the cartridge ina delta 1400 monitor, not sure how but i managed to crack the valve (uh-oh), it was pretty ginked up.  Okay so I took out the old valve, and installed a new Delta multichoice valve, (shower stall not a tub) arrows up everything looks ok, put in a new cartridge, (hot indiccator on the left like it should be).  turned back on the water to the house and water was running fine except it wont shut off ???.  turn handle to right and left, no change.  I havent odne plumbing for awhile so yes, I am outdated but I thought this would be pretty straight forward. What am I missing? the cartridge should control on off flow shouldnt it?
I looked at valve again, arrows up, as you look at the valve, hot on left cold on right, bottom to showerhead and top outlet blocked off , same as the monitor was installed. I must be missing something but cannot figure it out, would appreciate any help.
Tank you in advance,  E
  • Townhouse Transformation
