Installing Newel Posts in Loft
lunabean1 | Posted in Construction Techniques on August 19, 2013 10:14am
We’re finishing off a loft space and need to install a railing.  The ceiling under the loft is finished, so I don’t have access to the joists that way.  Up in the loft is OSB subfloor.  I can pull it up, if absolutely needed, but would prefer not to.  However, I really do want to sink the posts into the floor.  My question is this.  Can I bolt the post to the rim joist on the loft edge?  Post would be going through the subfloor in the loft, and sitting next to the inner edge of the rim joist.  I can place the post next to a regular joist as well, but it wouldn’t be secured to the joist.  Hope that makes sense.
  1. calvin | Aug 19, 2013 04:33pm | #1
    luna
    What you are proposing is something I wouldn't do for pay, but would probably give consideration to at some point in my life...................
    You can secure the newels to the rim, but how is the rim secured?  That will be your weak point.
    Think of the top end of the newel and all the rail secured to it in each direction, as the end of a 3+ foot pry bar.  The force exerted on the top of the newel etc is much more that any force directed at the bottom of the newel which is fastened to the rim.
    So, with that disclaimer-will what you propose fail catastrophically?
    At the minimum-fastened to the joist side as well, would greatly increase its stability and the strength of the system.
    1. lunabean1 | Aug 19, 2013 07:48pm | #2
      Well, looks like I'll be pulling up some subfloor.    Not the end of the world, though, and not the first time I've done it in this house (we added a bathroom up there, too.)
      1. calvin | Aug 19, 2013 09:26pm | #3
        luna
        To fine tune the layout, block between the joists (behind the post) and slide your post to center-then through bolt in place.
  2. lunabean1 | Aug 22, 2013 09:25am | #4
    Just ordered the posts yesterday.  They're 4 1/2" square box newels, with a solid 3 1/2" core.    Quick question.  What size bolt (diameter) should I use?
    I was planning on notching the bottom of the post 1/2" to 3/4" on all sides, so that the finish floor sits underneath the post rather than butting up to it.  That would leave 3" to 3 1/2" of post to be bolted.   (Really don't want to use shoe unless I absolutely have to!)
    1. calvin | Aug 22, 2013 03:46pm | #5
      luna
      On a deck, you'd use 1/2".  I don't think you'd have to in this case-3/8 or 5/16ths probably just fine.
      They've been held with long drywall screws for years................16 finish down to 10 for years b/4 that.  Dowells prior.
      Structural screws have been my remedy for repair.
      Your idea of rabbiting the post should cause no real problem either.
