removing particleboard
thomasedison | Posted in Construction Techniques on July 31, 2005 01:05am
I need to remove a large area of particleboard that was glued to the plywood subfloor. Any suggestions other than the manual method I have been using so far? I have looked for a power plane but all I seem to be able to find are 3″ door planes. Cutting the subfloor out is not an option 🙂
  1. DanH | Jul 31, 2005 01:07am | #1
    Leave the windows open in a rainstorm?
  2. Dave45 | Jul 31, 2005 02:17am | #2
    Don't even think of trying to use a plane.  That particle board may also have about a zillion staples in it.   I can suggest two options - one easy and one hard.
    Easy Way - Lay new particle board (or other underlayment) over the existing stuff and shoot anyone who shows up with any kind of glue.
    Hard Way - Set a circular saw (with a carbide framing blade) for a 3/8" cut and cut the particle board into sections.  You'll still have to do lots of scraping, but it may come up a little easier.
    To digress somewhat, I've always wondered if flooring guys get paid by the staple.  I've also wondered why they felt the need to pop 6-7 staples in obscure corners.  OK, I've had my rant.  I recently took up a tile over particle board kitchen/dining room floor and I'm still a little grumpy - lol.
  3. Isamemon | Jul 31, 2005 02:17am | #3
    I serioulsy dont know the name of the tool, but at the rental yard they have a tool and it is a walk behind chipper that is designed to chip junk off of concrete slabs, has about a 9 inch blade on it
    worked great have also used it to remove floor tiles
    but the particle board was only spot glued
    1. VaTom | Jul 31, 2005 05:19pm | #4
      Hadn't thought about it, but an asphalt grinder would proabably work well.  The small one I rented worked an area about 20 sq in.  Would make very fast work of particle board.  And whatever's under it if you weren't careful.PAHS Designer/Builder- Bury it!
  • Townhouse Transformation
