tight knot for a stringline
housenut1 | Posted in Construction Techniques on September 1, 2009 09:25am
What is the name of the knot  they use to keep a mason line taut  I’ve seen one recently for a fence installation but I could not figure out how to tie it.  My lines never stay taut, especially, when I hit them. If anyone has a link or can explain it, please let me know.
Mike
    observer | Sep 01, 2009 09:54pm | #1
    Either of these will work:
    http://www.animatedknots.com/rollinghitchboating/index.php
    http://www.animatedknots.com/truckersrescue/index.php
    1. housenut1 | Sep 03, 2009 06:50pm | #13
      Thank you for the links.
      Mike
  2. JTC1 | Sep 01, 2009 09:57pm | #2
    To make a loop in one end to secure on a nail:
    I use a double surgeon's loop.  Double the string back upon itself, then working with the loop and doubled string, tie a simple overhand knot but do not tighten it now,  pass the doubled end through the loop created by the overhand knot one more time.  Tighten by pulling on the loop (doubled end) and both strings formed when you doubled the end of the string. Trim the excess and burn the cut end to prevent untwisting / fraying of the string.
    Produces a strong, barell shaped, knot which pulls in a straight line (does not deflect string).
    To secure the other end -- the hard part.
    I use three different techniques:
    1) A masons line block -- wooden, "L" shaped, string wraps around the block and secures by wrapping around pre-cut grooves. After the block is wrapped, the string is s-t-r-e-t-c-h-e-d and the block is hooked onto a corner -- tension hold it in place.  BB or mason's supply house. Very handy.
    2 &3) Securing to another nail at the other end of your string run:
    2 - a tautline hitch -- google - I won't attempt to explain how to tie in words only. PITA, since to reuse your string, you must untie the knot, can be helped somewhat by tieing the last hitch with a loop -- AKA, quick release.
    3) My favorite: Use a HD galavnized nail for this end of the line -- the rougher the better.  Drop your loop onto the nail at the other end of the run.
    S-t-r-e-t-c-h the string to the HD nail, wrap string around the nail shank 4 or five times (looks like a coil spring around the nail shank) starting your wraps at the bottom of the nail.  While holding tension on the string, lift the string up and stretch a little more to allow you to get this turn of string on top of a few of your wraps on the nail shank.  The tension of the string holds against the previous wraps.
    This is almost impossible to do with non-galvanized nails as the wraps just rotate around the nail shank and the whole thing falls apart.
    3 strand, twisted, nylon, masons twine will stretch about 30% before it breaks.
    I like the day-glo pink twine -- easier to see and not trip over.
    Jim
    1. housenut1 | Sep 03, 2009 06:51pm | #14
      Thanks for the detailed tips.
      Mike
  3. rdesigns | Sep 01, 2009 10:50pm | #3
    For a fence post:
    You can use the same method JTC1 describes for a galvanized nail, only use the fence post itself to wrap around 3 times, then lift the stretched line over the wraps.
    Drawback:  This will always always leave the line stretched from one side or the other of the post, and will not be centered. But if you're establishing a line for the elevation of fence boards or post tops, it works just fine.
    You can very easily tighten or undo this simplest of knots.
    No idea what the name is.
    1. housenut1 | Sep 03, 2009 06:52pm | #15
      Thanks for the advice.
      Mike
  4. DanH | Sep 02, 2009 02:30am | #4
    I use a "taut hitch" for that. #1856 here: http://en.wikipedia.org/wiki/Taut-line_hitch
    As I stood before the gates I realized that I never want to be as certain about anything as were the people who built this place. --Rabbi Sheila Peltz, on her visit to Auschwitz
    1. housenut1 | Sep 03, 2009 06:52pm | #16
      Dan:
      Thanks for your advice.
      Mike
  5. mikeroop | Sep 02, 2009 04:23am | #5
    people r making this way to difficult
     drive a nail at both ends
    tie a loop in the first end
    hook on nail
    go to other end and pull string (not to tight)
    loop the string around your index finger and start twisting your finger so the string begins to wind back onto itself (maybe 10 times)
    put your finger on the head of the nail and release the loop onto nail
    pull string  between nails taunt with one hand and take up the slack with the other until string is very tight
    then pull loose end back over the twist toward the nail and let it unwind
    it will last for days
    to release pull loose end back toward first nail and bingo it's loose
    clear as mud
    once you do it it seems to easy
    1. levelone | Sep 02, 2009 05:13am | #6
      That's the way I learned.  Takes 10 seconds and any bonehead can do it.
      1. treehse | Sep 05, 2009 11:42pm | #24
        It is easiest and well explained but your wrong, some boneheads still don't get it. Think I will have them read this?
    2. lettusbee | Sep 02, 2009 05:34am | #7
      Step 3 n "Tie a loop in the first end"
      Therein lies the hard part.
      Ask 10 different people to tie a loop, and get 10 different "Loop Knots"  of varying effectiveness.
      Fishermen, rock climbers, newbies, cowboys, enigneers, masons, carpenters... all have a different way to tie a loop.
      Pretty cool actually
    3. dovetail97128 | Sep 02, 2009 09:07am | #9
      yep...Known as a "Mason's Knot" here cept I use only 4 twists then a quick loop over the nail after the slack is out.
    4. angusj | Sep 02, 2009 09:52am | #10
      I agree with mikeroop this is the easiest and fastest way by far (both to tie and untie) and the only people who will argue that are the ones that have never used it.
    5. JTC1 | Sep 02, 2009 06:29pm | #11
      >> clear as mud <<
      It was clear enough!
      Very cool knot --- I think I have a new favorite.
      Offshore sport fisherman will see a distinct similarity to the top end of a Bimini Twist and also the clinch knot.
      Tried it with less twists - not so successful.
      JimNever underestimate the value of a sharp pencil or good light.
      1. mikeroop | Sep 02, 2009 10:13pm | #12
        yea I always give it a few extra than what it needs but what it doesn't need to hold comes unraveled any way so all is good.
    6. housenut1 | Sep 03, 2009 06:53pm | #17
      Mike:
      I will try it today and I appreciate and really need easy. Thanks
      Mike
    7. Hudson Valley Carpenter | Sep 03, 2009 07:52pm | #18
      Yea, that's what I was thinkin' too.  You don't need to be an eagle scout to handle a mason line.
      The method that you described is the way I learned it, and perfect for the second knot.
      The initial knot is easy too.  Make a loop with your off hand, holding it between the thumb and index finger.  Place the thumb and index finger of the dominant hand through the loop, then rotate them around the outside of the loop's legs, making a doubled loop.  Pull the doubled loop together, then place it over the nail.
      Solid, fixed line but easy to remove with nothing to untie.
      Edited 9/3/2009 5:49 pm by Hudson Valley Carpenter
    8. Jencar | Sep 04, 2009 05:47am | #21
      That's how I learned too...
      Now can you explain how to make an extension cord "chain"?
        Dinosaur | Sep 04, 2009 06:44am | #22
        Just tie a series of slipknots, pulling the bight of each succeeding one through the previous one's loop. When you run outta cord, pass the end through the last loop. For 100-footers, some people double the cord before starting.
        That isn't real good for the extension cord, though, and unhitching one is a pure, steam-out-da-ears PITA with plastic-jacketed cords when it's cool outside. You're better off coiling it with alternating hitches.
        Dinosaur
      2. mikeroop | Sep 05, 2009 05:13am | #23
        do you understand that ( dinos reply)? or do you need more detail?
        1. Jencar | Sep 06, 2009 07:38am | #25
          Been rolling up cords like that since I was a "little" apprentice;
          just wanted to see someone explain it in writing!
    9. Clewless1 | Sep 06, 2009 08:35pm | #26
      That's the way a seasoned framer taught me, too. No knots to untie and fiddle with. If it loosen's, just redo it. Takes seconds.
      1. mikeroop | Sep 06, 2009 10:22pm | #27
        don't even remember where or who taught it to me but I'll tell ya one thing I've never forgot it.
    Dinosaur | Sep 02, 2009 07:18am | #8
    This is an easy one.
    On the end of the stringline, tie a bowline. You drop that loop over a nail at one end of your run.
    At the nail on the other end, you tie a 'scow hitch' (also known as a 'mud hitch'). You start by pulling the string tight in a counter-clockwise U-turn around the nail.
    Now, pass the bobbin under the standing part from left to right, then bring it up and pass it back over the standing part from right to left. Finally go back around the nail in a clockwise U-turn.
    Now repeat those moves, but in the opposite direction.
    Then do it again, and yet again.
    You now have four hitches figure-eighting around the nail and the string itself, stacked on top of each other. You can drop the bobbin and let it hang free; the string won't slip even on a bright common nail.
    Best part is, when you're done with your stringline, just pull the nail...and the hitches instantly disappear.
    Dinosaur
    foolish men call Justice....
    1. ronbudgell | Sep 04, 2009 12:02am | #19
      dinosaur,
      That's what I'd call a "Capstan Hitch". You can tie it in a mooring line with tension on it and slack it off without powering up the capstan.
      On the job, I think the best end knot if the one that mikeroop described, which I also know as the "mason's hitch". A second to tie and tighten, a second to untie and you can leave your nail in place for future checking.
      Ron
        Dinosaur | Sep 04, 2009 05:39am | #20
        Ron--
        Yeah, what I described is the same as the capstan hitch; the basis for it is it can be put on a single bit, pin, bollard, or pile and does not require a cross-bar, nor does it require you to have access to the bitter end of the line.
        Tugboat drivers call it the mud or scow hitch because it is used when making up a tow of mud, sand, or gravel scows--basic, no-frills open barges usually built without double bits.
        Dinosaur
