Using Azek inside
hammerelbow1 | Posted in Construction Techniques on August 18, 2009 04:48am
Plumbers set a shower unit and then the wall didn’t get fired out to cover the screws in the flange. I was thinking of using Azeck ..sp.. to cover the screws. Does this stuff hold paint well? Painters are using a high end paint on the interiors. I’m thinking of using this stuff because of the moisture that is prevelent in baths. Good idea or not?
Wayne
  1. rnsykes | Aug 18, 2009 05:15am | #1
    Nothing wrong with it on interior. I know guys who build shower surrounds out of it with raised panels and the whole works. Never done it myself, but I haven't seen it fail yet. I've used it for window packing in bathrooms, but thats as far as I got with it inside the house.
    1. deskguy | Aug 19, 2009 04:25am | #8
      any chance of talking those guys out of a picture or two. Really sounds interesting
      1. rnsykes | Aug 19, 2009 04:29am | #9
        Well, the house has been sold, so it may have to wait till the next time.
        1. deskguy | Aug 19, 2009 04:35am | #10
          dang... :)
  2. mike_maines | Aug 18, 2009 05:49am | #2
    Use 100% Acrylic Latex paint, no primer necessary.  Works great for that kind of application.
  3. JasonQ | Aug 18, 2009 07:46am | #3
    Got a bunch of it interior - in both our mudroom and the kids' bathroom.  Works a treat, holds paint like a champ.  Only caveat is that on the edges you might have to fill and sand if you want a good finish, since it's a bit porous.
  4. hammerelbow1 | Aug 19, 2009 01:05am | #4
    I got a 10' chunk from the lumber yard and gonna give it a try. Architec likes the idea (he should I'm saving his ####). If I nail it what do you use to fill the holes?
    Wayne
    1. mike_maines | Aug 19, 2009 01:07am | #5
      I like Bondo for filling nail holes in Azek, but you can use any wood filler, lightweight vinyl spackling compound, or a product made for that situation, Bond-n-Fill.
    2. mike_maines | Aug 19, 2009 01:08am | #6
      Be careful nailing it--it's prone to shattering.  Predrilling is a good idea, or use trim-head screws.
      1. hammerelbow1 | Aug 19, 2009 02:06am | #7
        I'm gonna have to predrill cause I'm nailing through the tub flange also. Thanks guys.
        Wayne
  5. loneframer | Aug 19, 2009 04:45am | #11
    We have had good results with painting Azek. I recommend light sanding, a high quality tinted latex primer and two coats of acrylic latex finish. Allow extra time for a full cure.
  6. Piffin | Aug 19, 2009 02:10pm | #12
    I use a lot of it in bathrooms. Solids milled to match casings/base and their T&G beaded board for wainscot. The painters love it. Light sanding with 120 to give some tooth on the smooth surfaces and go
  • Townhouse Transformation
