In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Adding basement walls
| Posted in Construction Techniques on February 17, 2008 06:30am
hi! every one i’m new to this site,thanks  the one who going to reply
I want to add walls to my existing concrete fondation by diging about 16“ lower  down the footing to get a 8 feet basement?
What thecnique should i use to do the job!
                                  thanks
  1. JeffinPA | Feb 17, 2008 06:32pm | #1
    IMO, an engineer.
    If I understand you, you want to undermine your footings and dig down since you only have about 6'8" basement ceiling.
    There are methods and ways, but the load must be transferred down to the new footings.
    1. deersniper | Feb 17, 2008 07:27pm | #2
      yes, but which way is better,do i do that in section of 3-4 feet at the time,remove the concrete slab dig under the walls 3-4 feet, skip a section  dig again under the walls 3-4 feet etc.
      poor one walls at the time with the footing section by section 3-4 feet,drill under the walls every 16'' , put rebar with epoxy for the new section and rebar for the side when i will poor between section
      is this a good way or you know a better way!
      thanks!
      1. JeffinPA | Feb 17, 2008 09:30pm | #3
        Hmm
        I've never undermined all the way around.  Yes, that would be the way to do it but that is a serious workout.
        Is it a square box with full unfinished basement?
        I might consider jacking up if the exterior topo could handle it.
        You would have to redo stoop, stairs, regrade, fill in siding, etc, but might be easier.
        1. deersniper | Feb 18, 2008 03:15am | #4
          thanks for your advise!!!!!
          Is anybody have something else in mine? how can i do that project!
        2. deersniper | Feb 18, 2008 05:07am | #7
          sorry,i forgot to answer your question.
          yes it's a square box with finished basement.
          i don't thing the footing is very wide,and walls and footing sitting on solid rock!
          1. JeffinPA | Feb 18, 2008 03:39pm | #8
            If the walls are sitting on solid rock, how are you going to dig down?  And with a finished basment, are you attempting to salvage finished basement when you do this?  Correct me if i am wrong, but you are intending on undermining and underpinning from the inside right?
            Regarding the how, I would invest into one of those mini skid steers that you stand on to operate and put in a ramp to access the basement.
            When done, use opening for egress door.
            Need to vent well due to gas fumes but that is a project that would be so labor intensive I could not imagine the end of it.
      2. MikeSmith | Feb 18, 2008 04:01am | #5
        deer..... old guy i know did the entire foundation of his hardware store exactly the way you described....
         i'm thinking 10 years
         foundation was about 60' x 60'Mike Smith Rhode Island : Design / Build / Repair / Restore
        1. deersniper | Feb 18, 2008 04:48am | #6
          thanks! I think it's a good way to do it,it's more work ,and next door is pretty close to my house
          any more idea?
          love this site?full of information
  2. John_Carroll | Feb 18, 2008 04:21pm | #9
    I've converted part of my crawlspace into a basement. There are pictures in discussion # 73774.8
Industry-First Cordless Rebar Cutter and Bender
A brushless motor and 36v batteries power Metabo HPT’s cordless rebar bender and cutter.
  • Podcast 484: PRO TALK With Color Consultant Paula Gaull
  • Using Liquid Flash at a Wall-to-Foundation Connection
  • Forming Foundation Walls
  • Track Lighting for Functional Ambiance in Busy Spaces
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
